Engine Self Test: 1996-97 2.5L V-6 Engine
Diagnostics
Post by 1stgenWizard » Wed Jan 15, 2020 11:33 pm
Overview
1996 and 1997 Probes were equipped with an On Board Diagnostic (OBD) series 2 system to detect malfunctions in sensors and notified the driver through the Check Engine light on the instrument panel.
The 'Check Engine' light or MIL (Malfunction Indicator Light) light on the instrument cluster illuminates when the ignition is turned to the 'On' position. It will go off a second or two after the engine is started. If the light stays illuminated after the engine is started or illuminates while driving, there may be a problem with the engine. Checking for error codes is an easy way to find out what's wrong and what, if anything, caused the 'Check Engine' light to illuminate. Unlike previous models, there's only one way to retrieve the codes from the computer... an OBD-II compatible scanner. Simply connect it according to the manufacturer's instructions and write down the codes that appear.
Clearing the Codes
Clearing the PCM of codes can only be achieved by either using the Clear function on an OBD-II scanner, or by disconnecting the negative terminal on the engine battery for a couple of minutes.
  • Engine Self Test: Codes
    Code Sensor or System
    P0100 Mass Airflow sensor or circuit fault
    P0110 Inlet Air Temperature sensor or circuit fault
    P0115 Engine Coolant Temperature sensor or circuit fault
    P0120 Throttle Position Sensor or circuit fault
    P0125 Excessive time to enter closed loop
    P0130 Heated O2 sensor or circuit fault
    P0134 Heated O2 sensor slow response
    P0135 Heated O2 sensor heater or circuit fault
    P0140 Heated O2 sensor slow response
    P0150 Heated O2 sensor or circuit fault
    P0154 Heated O2 sensor slow response
    P0155 Heated O2 sensor heater or circuit fault
    P0160 Heated O2 sensor slow response
    P0170 System fuel too lean
    P0173 System fuel too rich
    P0300 Random misfire detected
    P0301 Cylinder number 1 misfire detected
    P0302 Cylinder number 2 misfire detected
    P0303 Cylinder number 3 misfire detected
    P0304 Cylinder number 4 misfire detected
    P0305 Cylinder number 5 misfire detected
    P0306 Cylinder number 6 misfire detected
    P0325 Knock Sensor circuit malfunction
    P0335 Crankshaft Position sensor or circuit fault
    P0340 Camshaft Position sensor or circuit fault
    P0400 EGR flow fault
    P0420 Catalyst system efficiency below threshold
    P0430 Catalyst system efficiency below threshold
    P0440 EVAP sytem fault
    P0443 EVAP purge solenoid or circuit fault
    P0500 Vehicle Speed Sensor or circuit fault
    P0503 Vehicle Speed Sensor or circuit fault
    P0505 Idle Air Control valve system fault
    P0510 Idle switch fault
    P0552 Power Steering Pressure switch or circuit fault
    P0553 Power Steering Pressure switch or circuit fault
    P0603 ECM Keep Alive Memory test error
    P0605 ECM Read Only Memory test error
    P0703 Brake On/Off switch or circuit fault
    P0704 Clutch pedal position switch or circuit fault
    P0705 Transmission range sensor or circuit fault
    P0710 Transmission fluid temperature sensor circuit malfunction
    P0715 Turbine Speed Sensor circuit malfunction
    P0731 Incorrect Gear 1 Ratio
    P0732 Incorrect Gear 2 Ratio
    P0733 Incorrect Gear 3 Ratio
    P0734 Incorrect Gear 4 Ratio
    P0740 Torque Converter Clutch circuit malfunction
    P0745 Pressure Control Solenoid malfunction
    P0750 Shift Solenoid #1 malfunction
    P0755 Shift Solenoid #2 malfunction
    P0760 Shift Solenoid #3 malfunction
    P1000 ODB II readiness function code
    P1170 Rear Oxygen sensor voltage fixed
    P1173 Front Oxygen sensor inversion
    P1195 Barometric Pressure sensor circuit malfunction
    P1196 Starter circuit malfunction
    P1250 Fuel Pressure Regulator Control solenoid malfunction
    P1345 Cylinder discrimination signal
    P1402 EGR Valve position sensor
    P1485 EGR Control solenoid
    P1486 EGR Control solenoid
    P1487 EGR Check solenoid
    P1521 Variable resonance induction system (VRIS) solenoid #1
    P1522 Variable resonance induction system (VRIS) solenoid #2
    P1523 High Speed Inlet Air solenoid malfunction
    P1609 PC Minternal circuit malfunction
    P1709 Throttle Position sensor malfunction
    P1720 Vehicle Speed Sensor circuit malfunction
    P1743 Torque Converter Clutch Control solenoid malfunction
    P1744 Torque Converter Clutch solenoid malfunction
    P1765 3-2 timing solenoid malfunction
    P1792 Idle switch malfunction
    P1794 Loss of battery voltage input
    P1795 EGR boost sensor malfunction
    P1797 Clutch Pedal Position switch or neutral switch circuit malfunction
